My tach is not bumping around but seems to have a problem at RPMs below 1000. When in the water out of gear holds right around 1000 rpm but when I put in gear it drops sometimes to zero, sometimes two hundred sometimes 600.... Once I increase throttle all good. At wot I am getting a reading of 5500 to 5600 on a twenty foot boat with 15x17 prop. Checked gray wire at wiring terminal block and all looks good. Anything internally in tach that could be impeding signal? Thoughts?
BTW had to replace stator last year and test of charging system at battery voltage was 14v after replacement. Did not do anything with rectifier thinking voltage output looked correct.
Thanks in advance
Thanks in advance
