TACH ISSUE
izuizme
I have a new (old) boat I just noticed that when I turn off the motor the tach needle does not stay at zero rather it drifts up to around 2k and stops there.Please advise a remedy.
The Marine Doctor
Re: TACH ISSUE
That is normal.<br /><br />If it was to drift up to 2k when you turn the key to on...then its a problem.<br /><br />TMD
tradin
Re: TACH ISSUE
funny mine does the same thing my question is does that draw power from the battery i find if i turn the key on and off again the tach goes back to zero i have been doing that worried about drawing power from battery when boat is idle thats why i do it our does it not matter
Skinsk
Re: TACH ISSUE
The tach is not spring loaded, it's more like a reostat, so when you turn the motor off, you are also killing power to the tach. Therefor it just stays basically where it was when you killed the power. <br /><br />It does not draw any power once you turn the key off.
