Tach not working and engine won't shut off...
ahifever
********1986 Yamaha 90******************<br />About a month ago I had this same problem. I replaced a corroded main ground wire and it fixed the problem...or so I thought. On my last trip out<br />engine was running fine until about an hour into the trip. Engine would shake violently, above 2000 rpm and tach stopped working. Below 2000 and it would run fine. <br /><br /> I got home and tried a few things(changed CDI unit,checked ground wires etc.) I also changed the wire harness assembly on the motor(although it was an older one from a spare motor)and still have the problems. Can someone please shed some light? <br /><br />Thank you
ivar
Re: Tach not working and engine won't shut off...
Have you checked the main fuse? <br /><br />Shaking above 2k is due to ignition cuts out if oil level is too low. <br />It still sounds like you have some faulty connections somewhere .
ahifever
Yes, fuses have been checked. I'm gonna order a new <br />engine harness and see what goes from there. Thanks for the response.
