Boat called Bertha
- Joined
- Jun 16, 2017
- 4
Discovered this when launching boat yesterday. Brought boat up river to the my dock. Fired kicker engine as well. Battery gauge showed a slight improvement. Battery is new Kirkland deep cycle. Ran some volt tests. With kicker only meter read 13.13 with slight increase in rpm. Fired the big engine, 13.02. With only big 12.07 @ idle. 12.09 down to 12.02 with increased idle. 12.00 with more throttle. Remember tach not working so can't give a number; but all cylinders firing. (Also noticed last season that the tach would function and then drop to zero and then jump back up). Returned to idle 11.98. Both engines at idle 12.47. Kicker only idle12.57. Increased rpm 13.02.
I've looked at info regarding the stator, rectifier and regulator. Have not disconnected any wiring to test yet; just hoping someone could give the proper procedure for my 1996 Mercury 115hp 2 stroke engine. Our local marina is 3 weeks behind and we have company from Michigan arrive June 30 and hoping to go fishing on Lake Erie. Any advice is appreciated.
Thanks in Advance
John
Thanks in Advance
John
