Tach Problem?
G3Boats
Lately, the tach on my Yammie 60 is going nuts sometimes. It will race to the max, go down, go up, then settle on the rpm and not every time I go out. Can this thing be lubed, or is it an electronic sending unit?
99yam40
it receives an electrical signal from the lighting coil.
might try running the setting switches back and forth a few times to wipe the connections inside to get better connections
G3Boats
Pardon my ignorance, but are they under the dash on the back of the tach, or on the engine? Thanks for your help.
99yam40
on the tach
and check grounds along with all wires for bad connections
