Hi, new here but not to boating. I have looked at lots of threads regarding bouncing tachs and could not find an answer to my problem.
Motor is a Marine Power 454 with GM high energy ignition, inboard shaft drive.
I have had problems with erratic tach readings since the motor was installed (1994). Replacing the tach (with a Medalion brand guage) mad it better but it would occasionally read high, a tap on the lense would bring it back in line.
I have recently upgraded to Faria guages and I can't get the new tach to read close to correct. I fiddled with the switch on the back to no avail. I ran a new wire from the tach output at the engine harness, I ran a new ground. I sent the tach back, it is OK. I tried providing power from a completely independant power source to rule out some interference.
While installing a Crane ignition kit in my wifes 66 Galaxie I noticed they recommended installing a resistor in the signal line if the tach was erratic. This did not help my boat.
The boat has an auto pilot with the drive motor built into the helm. Its pretty close, could the motor magnets be causing interference? There is no difference if the Autopilot is on or off.
Is there something different about GM HEI I need to know?
I'm stumped, any ideas out there?
Thanks!
Thanks!
