I have a '76 1150 Mercury.
I have a tach hooked up but its an older tach. The boat I bought had all quicksilver gauges but when I had my motor put on the boat the guy took my older tach and used it. I want to use my quicksilver gauge.
It has 3 wires coming out of the control for the gauges. White, Brown, Black.
White = Positive
Brown = Tach sender
Black = Ground
Is this correct?
Also on the back of my quicksilver tach it has range selector.
1 = 4cyl
2 = 6cyl
3 = 8cyl
4 = 12 pole alter
what setting should this be on for my motor?
Also when hooking up the gauges I can run the positive wire from gauge to gauge to insure all gauges come on after key is turned on?
White = Positive
Brown = Tach sender
Black = Ground
Is this correct?
1 = 4cyl
2 = 6cyl
3 = 8cyl
4 = 12 pole alter
