Re: tach question
hey guys, still trying to get my tach hooked up, looked all over motor for gray wire, none tried to connect to all connections on terminal block hooking the other wire, black to ground then hot nothing, my tach is an older aqua meter and dont actually know if it works, there is ajustments on the back but i haven't moved anything yet because i figuard it should at least move the neddle once i get it hooked to the right term then will try to adjust to correct setting. any help will be so very much appreciated. thanks Phil
