tach rewire
Benny1963
im going to wire past the rubber connector on my control box for my tach
can yall tell me what the wire colors in control box are for the tach such as sender/ ground / and ignition .my tach has gray for ground red for ign and
white for send any help or diagram would be great, my seloc is terrible in that area thanks bennyb
Joe Reeves
Re: tach rewire
Sender (sensor) = Gray
Ground = Black
Ignition (voltage when key is in the ON or START position) = Purple
ezeke
Re: tach rewire
In case you want to try to use the amphenol wires, the left hole is purple, the top center is gray, and the right hole is black.
