hey folks,<br /><br />i just got around to installing my new tach rigging kit part no. 6YR-W0035-E1-00 on my 1989 grady with a 1994 yamaha 200sws. everything was plug and play and installed pretty easily, now i have a couple of problems and questions, first problem is tach only reads "0" with engine running and tilt/trim display a little bouncy. all dip switches were set correctly and double checked. original tach(analog) tilt/trim gauge were working with the original 1989 engine. when i had the engine replaced with the newer 1994 engine tach and tilt/trim did not work. dealer said i needed newer tach with tilt/trim which i just installed. when i purchased rigging kit it did not come with instructions on how to use the new gauge. the new gauge has two buttons "set" and "mode". do i need to use these buttons to make it work ? does it need to be calibrated ? any help would be greatly appreciated......<br /><br />thanks, stoney
