tach settin
da83moon
1979 evinrude 55975 55 hp evinrude.
Just wonder ing got a tach the other day it has 4 cyl, 6 cyl, 8 cyl, and 12 pole alternator. For this engine which is it?
da83moon
Re: tach settin
Thanks It was set to 12 pole and the dern thing kept saying I was WOT @ 3400 rpms. This is a new one and I was like there is no way. Thanks Just out of curious why the 6 cyl when its a only got 2?
F_R
Re: tach settin
Just curious, what kind of tach is that?
F_R
Re: tach settin
That's why I don't recognize the settings.
Most tachs are marked in poles or pulses. A 12 pole alternator has 6 pulses per revolution. 10 poles = 5 pulses, etc. Your 50 should be 12 poles or 6 pulses.
EDIT: Better check that last statement. It might be 10/5.
bonz_d
Re: tach settin
Not to hijack this thread but I have a question.
When you mention alternator is that the same as a stator in the OMC's or is that different?
Joe Reeves
Re: tach settin
Bonz.... The stator is the beginning of the alternating charging system.
Da83moon.... The OMC (Evin/John) engine alternating systems emit six (6) pulses of which the tachometer operates upon, hence the six (6) settings. This pertains to engines with any number of cylinders.
bonz_d
Re: tach settin
Thanks for the info. More questions, will start a new thread.
Again thanks and sorry for the interuption.
