Tach wiring for a '67 Thunderbolt 500?
zonaman
I've got a tachometer I'd like to wire up tp my 1967 Mercury Thunderbolt 500. The starter battery for engine is separate from the one I use to run accessories (i.e. instrument lights). How do I wire this up? I'm not familiar (yet) with this ignition system other than to note it doens't seem to use points or a coil. Below is the wiring diagram that came with the tach.
Thanks for your help.
mmf
Re: Tach wiring for a '67 Thunderbolt 500?
I think your motor has a magneto and you cannot wire it up per the instructions you have. What is your serial number of the motor? If it is a magneto, the points in the magneto did not run on battery ignition, they break and make the magneto coil and it is a totally isolated, self supplied voltage, if you hook anything up to the terminal on the magneto, you will fry your ignition.
zonaman
ser# 2214875- That's a type II (as per Seloc) isn't it?
merc850
That motor has Thunderbolt electronic ignition and your best bet is to get an alternator driven marine tach from a dealer or this website.
