Re: Tach wiring.
Nightser,<br />I have just installed one of the Tachs from Beede and love it. I just wired mine in, by using a Voltmeter and finding the correct wires. <br /><br />I attached the Light pole to a wire that I then ran up to one of the other instruments lights.<br /><br />Attached the Ground to a ground wire that was in the vicinity of where I was mounting on the dash.<br /><br />For the 12 Volts, I would try using a Voltmeter on your connector that you say that you have in the boat, to find the 12 Volt wire that is switched by the key.<br /><br />The signal wire may be a bit trickier to find out which one it is. Mine was labeled on the engine block, that the Purple for my Force 125 engine was the wire for Tach. I am not sure what yours would be, but you can probably find out in the manual or pick up a clymers shop manual, that should tell you this.<br /><br />The 12 P is for a 12 Pole Alternator. I had to get mine from Beede to support up to a 20 Pole alternator for my weird engine. I would say that this should be correct for this engine, or you can call Beede's tech support, they were great in working with me.<br /><br />Hope this helps<br /><br />Thanks,<br />Bryan Cox
