Thank you very much.Best diagram I have seen.Your time is greatly appreciated.This wiring diagram should help
ITYWF that the three pin connector near the cntre of the diagram is for the tachometer
The black wire (C) is ground (battery negative)
The purple wire i(A) s a switched positive supply
The grey wire i(B) s the tachometer signal from the rectifier/regulator
