Tach won't work
simbot
Hi everyone I have just bought my second boat for the family its a older 70s trihull with a 1975 Merc 85hp motor, I had it running at home however wouldn't go at the launch. It turned out to be the cdi and the trigger, 900 bucks later I'm on the water finally. I read that the tach output is not on the new cdi unit so my factory tach just buzzes and is doing nothing can I get it to go again.
Chris1956
Re: Tach won't work
Look under the wrap cowling. The tach signal is the brown wire. It needs to be connected to one of the yellow stator wires in order to power an aftermarket Tach. If you still have the old Mercury tach, they were powered by the switchbox, and if you do not have the brown terminal on the switchbox, you are out of luck. If so, spend the $60 and get a new aftermarket tach.
