Tach works at low rpm, sometimes
MarkyMark
my tach works at idle to low rpms only, and only this only sometimes. As tachs are pretty expensive to, any suggestions where to troubleshoot first? 1994 Johnson 140 in a 23' Hurricane.
HighTrim
Re: Tach works at low rpm, sometimes
I would start by testing the rectifier as per Joe Reeves instructions in the FAQ. If all is well there, you will need to check the signal source, or simply try a loaner tach with alligator clip hookups to see if the tach itself is fautly.
