Re: TachNOmeter
Bad connection? Try connecting a battery charger to the leads. If it works directly at the tach, and not at the coil, you have a wiring problem. If it doesn't work at the tach, that tach itself is bad...
That's a good place to start...
You can also test accuracy of a tach with this method. When the charger is connected, you should get the following reading.
* 1800 rpm for an 8 cylinder,
* 2400 for a 6 cylinder
* 3600 for a 4 cylinder
Good luck!
