Hi Guys,
Not sure if this should be in the mercruiser section or the diesel section.
Anyway I will start...
My tacho is on its way out it seems to be going nuts... when I start it idles anywhere between 4-5k (its not idling at that but tach says it it) it will jump around as you drive.
Anyway its on a mercruiser 1.7 dti io and normally I know diesels are meant to have a special tach, however this looks like a tach for a gas I/o - is this possible/correct? I cant get this tach anymore so want to make sure I buy the correct kind so any help would be great - pics below:
Thanks
MODEL: FARIA TC9384A (I believe)
Thanks
