I am having trouble with a tacho on a 1998, 75 force outboard. It keeps reading high from only a couple of hundred revs to about a thousand. The engine noise doesn?t change but the tacho can just start reading high. I have checked the connections on the back of the tacho and also the connection in the loom by the throttle control.
The boat is stored under a tarp & moisture builds up at times as a result.
Not sure what to look at next.
I could try to find another tacho but I would like to know if anyone has any other ideas.
