Tachometer for 1970 Evinrude 115
farmuse
Can anyone here give me information where I can get a tach to use on the E 115 and how to wire it ?
Thanks in advance
farmuse
Re: Tachometer for 1970 Evinrude 115
Can any type Tach be used on this type charging system? Like if I wanted to use a automotive tach?
emdsapmgr
You'll want to locate a marine tach. Test tachs have a switch on the back which will let you adapt to any type marine ignition system, outboard, stern drive, etc.
ezeke
You will need a universal marine tachometer. The signal wire will be connected to the terminal block where one of the yellow wires from the rectifier is connected.
F_R
There should be a grey wire near the key switch. That is the tach signal wire.
No, a car tach won't work. You need one that gets its signal from the alternator (nearly all modern outboards)
farmuse
I found the grey wire it is not attached to anything. Where is the best place to buy a universal tach
