Re: Tachometer for '72 1150
Most any aftermarket OB tach will work on that motor. You need to look to see if there is a brown wire on the switchbox, on the non distributor side. That is the tach signal wire and it is set up for the old Merc tachs, which no longer exist(or are hard to get). If so, that needs to move and connect ro one of the yellow stator wires, at the rectifier.
