I recently tried to install a Teleflex tachometer on 1991 Mercury 60HP. Per Tach instructions I connected Gray wire from engine harness to send input, and connected ground and power. Tach seems to read correctly up until around 4000 RPM after which it DECREASES as the engine further speeds up. Per the tach instructions the alternator setting is set to "6P".
Thinking it may be a bad tachometer, I exchanged it, but the new one did the exact same thing.
Any ideas?
Any ideas?
