Tachometer ID please.
henrye718
Need help figuring out who makes this tach and see if I can buy a replacement or a substitute. If you look at the picture you will see it has oil, temp, etc. etc. warning lights. The boat factory and dealer dont know :confused: . Its being used on a 2000 model year Johnson 60 HP two stroke outboard.
Thanks all!
R.Johnson
Re: Tachometer ID please.
Look's like am OMC part to me. Check in a OMC accessory catalog if possible.
Seem's about the time OMC's engine chek system came out.
emdsapmgr
Looks like you have the old OMC "classic" gauges in your boat. I believe that line was phased out a few years ago. Doubtful that you will fine a new replacment around, but you can call Bombardier dealers and ask if anyone has a new leftover which will match yours. You should check out the newer Bombardier "Tech" series which is similar. They make a system tach 177107 which should work.
henrye718
Thanks! I have found some possible replacements now that I know what I am looking for.
