country cadillac 48
- Joined
- May 14, 2013
- 35
Hope someone can give this old timer some suggestions with my 1979 70 hp MERCURY as to why when I connect my tachometer the needle pegs. The boat did not have a tachometer when I got it, so I went to the local boat repair shop and they set me up with a used Air Guide Sea Speed Tach. It has a green and a black wire out the back and the letters 2GC printed on casing and 999 in a little white tag. I also got the plug in connector that goes to the control box only it has a white wire in addition to the green and black and I would guess that's for a lighted tach. So I thought I would connect the tach to the wires out of the box connector to see if it worked. Started the engine and it pegged the tach, which I immediately disconnected. I read the posts and I don't know what these different pegs mean. I also found the charging circuit not working and had to replace the rectifier and that fixed that problem and gave the control box power to the tach plug in.. I would really appreciate some help and thanks for your time and sorry about rambling on.
