tachometer question
slabhunter
I have a console coming for my 16ft Bass Tracker and I'm going to either run a 25hp 1985 Evinrude electric start or a 50hp 1972 Evinrude on it. Need to see how well the 25hp pushes it. One of the reasons I bought this (used) console is because it had speedo, tach, volt, tilt/trim gauges with it and for $69.00 it was a much better deal than having to add them to one without them. The speedo and voltage hookups shouldn't be any problem but I'm concerned about the tach. Number one is it compatible? And number two will I fry any electronics if I hook it up wrong. Some tachs are protected against incorrect hookup but that doesn't guarantee that what it's hooked up TO won't do a meltdown on me. Here's the info from the seller: <br />0-7 RPM systems check tachometer for use on 5-6 pul/rev alternator equipped outboards<br /> <br />Any advice or warnings guys?<br />Thanks,<br />slabomatic<br /><br />75% of the earth's surface is covered in water. It is obvious from this fact that the good lord meant for man to spend 3 times as much time fishing as working.
Laddies
Banned
Re: tachometer question
that means the tach. runs off the alternator not the ign. ck you motor at the rectifier and see if it has a gray wire hooked to one of the yellow wires that run to the harness that goes to the front of the boat, if not you will have to install one--Bob
