Tachometer
bobwalter
I have a 2002 Yamaha 90 hp 2 stroke. The tachometer has been accurate. Last time out, it read 2000 at idle and when cruising at about 3500 rpm it read 5500 to 6000.WOT is 7000+. I did nothing to the boat other than charge the trolling batteries under the console. Otherwise nothing. What is going on???
Thanks,
Bob
WillyBWright
Re: Tachometer
Did you bump the wires? Make sure your cranking battery connectons are clean and tight. But I'll bet the rotary switch on the back is tickling two positions.
