Re: Tachy related question
The half-moon connector is the one your after. The purple wire provides 12 volts when the key is turned. Someone must have used it to power something else(Common). You just need to find out what, by tracing it down. When I posted that link for the harness, it was still available for the OMC, but not the Merc. Must have made a decision to stop selling both. I would find out where that purple wire goes to and then we will see if it can be rearranged to power whatever it is some other way, so you can get a harness to plug in there. I'll look around and see if I can find another. In the meanwhile, did you look for the gray wire under the console? Usually when someone pulls power from the plug, it's for a Gauge on the dash. Check it out. You can also get the harness at Cabela's. Just go to there site and type in "tachometer wiring" in the keyword search box at the top left. When the teleflex Tachs come up, click on them and scroll down to the harness.<br /><br />
Cabelas<br /><br />Also, there's one on E-Bay for sale:<br /><br />
E-Bay Harness <br /><br />Looks like this:<br /><br />
