2005 200 yamaha out board tack problem new tack is set to 12 same as old one was also set to 12 it did not work either on back of tach purple wire is hot 13.5 volts engine running black ground is good gray signal wire 6 volts running tach dose not work i am looking for the proper way too check this tack if anybody knows thanks
