Tackling Gimbal Bearing
JasonGS
I am extremely new to gimbal bearing removal/installation... I just received the gimbal bearing along with bellows, gimbal installer and alignment tool... I have a slide hammer to remove it... Is there anyone that has a step by step instructions on how to remove and install gimbal bearing??? What else do I need?
This is what I bought:
http://www.ebay.com/itm/280951794415?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
http://www.ebay.com/itm/310261940462?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Thank you,
Jason
JasonGS
Re: Tackling Gimbal Bearing
Sorry i didn't mention I had already bought 2..
JasonGS
Got the outdrive off now what do i do?
tpenfield
Do you have access to a maintenance manual for this outdrive (although it is an OMC you might find an online version in the 'stickies' at the top of the OMC forum)
That will give you a step-by-step.
Marine engines are only scary the first time you work on them, thereafter, they are just the typical pain in the a--.
Basically, you are going to pull the gimbal bearing, put the new one in
Replace the u-joints, grease them
Check the engine alignment, adjust as needed.
re-install the outdrive
Test everything
Go boating.
JasonGS
So I just got the boat back together and it sounds like everything is now running smoother.. I no longer have any noise coming from the outdrive... My only concern is I don't know if it is done correctly anything I should check to be sure.... the gimbal is flush inside the housing..
