Larry E
- Joined
- Jan 1, 2012
- 161
I am working my way through the electrical system on my 74 Seaswirl. I am having an issue with the starter cranking with the key in the momentary position but then when the key is released the starter keeps working. I have to remove the battery cable to get it to stop. When I reinstall the battery cable the starter does not respond till I turn the key to the momentary position on the ignition switch... SOOO needless to say I need to work this out but my mind is becoming boggled with all the posibilities. I have the Ignition switch hooked up per the picture of what it was like when I bought the boat. There are two wires on the Battery terminal (orange and red). However the great wiring diagram that one of you gave me shows only the orange wire being hooked to the battery terminal with the red going to the amp meter. SO if you have an opinion about this I am wanting to listen. Like I said this a 1974 Seaswirl with a GM 2.5 motor.
Larry E
Larry E
