Taking jon boat out in cold water
Chryslerman123
I recently purchased a 1976 loweline 14ft jon boat. I put on my chrysler 20 hp outboard that I got running. It is cold here in Kentucky but I really want to go test run my boat and make sure my outboard runs ok. I planned to wait until spring but I am just too anxious to wait. I am an experienced boater but have never been in a jon boat. I do know that the stability of a 1436 jon boat is not that great. The boat is rated for 20hp max by the way.
My fear is that something might happen and I could turn the boat over or fall out in the cold water which is about 35-40 degrees. That does not give you long to get to shore. The lake I would take it to is 300 acres and is very calm this time of year.
I was just wondering if this would be safe?
Opinions are appreciated. Thanks.
ondarvr
The chance of getting dumped in the water is the same no matter what the temperature is, take it slow and see how it handles.
fhhuber
The main danger in calm water is trying to turn too sharply at too high a speed. The 1436 isn't anywhere near as unstable as a lot of other boats...
Just take it easy as you get used to the boat. (and don't forget to put in the drain plug)
fishrdan
I wouldn't worry about it. I take my 1436 jon boat out all the time in the winter and never give it a second thought. Though the water I'm in is 52* year round coming off the bottom of a dam. Only time (once) the boat got squirrely on me was when I crossed a wake too fast, doubt you'll see that in the middle of the winter on a 300 acre lake.
Strap on a PFD and go have fun!
SeaDooSam
Go right ahead, enjoy the boat! Just don't turn too fast and you should be fine. Make sure you bring paddles too Just in case
gm280
Common sense IS your friend during the cold weather and water. Take it slow and easy and become familiar with the boat and engine before doing anything at max speed. Boats have a tendency to teach as you drive around. Learn slow and you should have a very enjoyable time. I am sure the cold wind coming into your face will have a lot to say about things as you travel on. Absolutely a PFD is a must without question. And also let others know where you are going and when you are to return. That again is mere common sense. Enjoy!
Teamster
Make sure your wearing a life jacket,...
If your worried take someone with to watch from shore,...
dingbat
The deadly cold water is what scares me.
as it should....between Strper fishing and water fowl hunting we loose 5-6 guys a season to cold water "accidents". Most circum to cardiac arrest in short order.
Don't count on getting back into the boat if you fall overboard. Ain't going to happen with winter clothes on in the time, and loss of dexterity, allotted.
A life jacket will make recovery (body) easier.
