taking on water with engine not running
Status
Not open for further replies.
jkleinh
i have a 87 omc cobra 5.7 i got a stream of water comming in at the transom just above where the two exhaust manifolds meet i see two bolts at the bottom is there more behind the coupler ?do i have to pull engine to get to them ?or is there somthing im missing ? help!!!!!!!!!!
QC
Re: taking on water with engine not running
I am moving this over to the I/O section. You'll get more help there ;)
180shabah
How old are you bellows? A split in the u-joint bellows can sink the boat. Other possibilities: leak around y-pipe, water hose leak(or broken fitting).
Start you inspection externally and work your way into the hard to get at areas.
180shabah
You can also post pictures - it really does help sometimes.
doug_offshore
Hi,
Have you got anywhere with the leak problem?
I have had the same problem for ages.
Eventually paid a packet to have 2x bellows and gimble bearings replaced.
Guess what? STILL leaking!
I am at a loss and totally deflated, having paid the shop to 'find the leak' and still no joy.
Looking forward to some constructive advice.
Cheers,
ezmobee
Welcome to iboats doug. Your best bet is to start a new thread with your problem. Good luck.
Status
