O.k... I just bought my first bought, a fixer upper. The drain plug leaked bad. I replaced it with a new one. Took the boat out over the weekend and had it sit in the water for several hours. No leaking... I then took the boat out around the lake a couple of times... I ended up with a little bit of water in the hull. I mean, maybe a half gallon... I emptied it out that night, left the boat in the water, took it out again the next day, the same thing... Is there a less complicated and inexpensive place to start the fix. Thanks....
