GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Mariner 150 V6. Temp fluctuates between 160 and 170 at full rpm. Man I bought the boat from said he removed the thermostat and said thats the reason for weak pee. Is there a problem with this or can I leave it as is.<br /><br />Thanks Rick
Replace your t/stat and check out the water pump.<br />The motor needs to run at the correct temp,that's one sure way to get fouled plugs.<br />keep posting
