Talk to me about the 1975, 75 hp Johnson electric shift
padlstandg
It's sitting on a stand in my driveway and i'm not sure whether to send it for recycling or try to restore it.<br />What's common knowledge out there?<br />I had it running several years ago but had no boat to put it on.<br />It needs new electrical cables but seems like it might be a good motor for somebody.
Yepblaze
Re: Talk to me about the 1975, 75 hp Johnson electric shift
Is that the three cylinder. There are some guys that would definitely salivate over that one even with the electric shift. <br /><br />Do a search here in the forum on electric shift if you want info about how it works.
padlstandg
Thanks for the search tip, that was useful. I'm pretty sure it's a 4 banger<br />Made a lot of noise when I started it momentarily without the lower unit attached.<br />I read in line about some guys are useing these things as dragster engines.
seahorse5
There was a 75hp electric shift made in 1965, but not one in '75. What is the model number?
padlstandg
the model / serial # is 75393E E03864<br />I spoke a little bit with Wilbur Goltz of the texas chapter of the antique outboard motor club and he thought it might be a 63 model. Does this sound right?
Franki
Are you sure those numbers are right??<br /><br />These are the models I know about from your HP..<br /><br /> 1960 V4S-V4SL-12<br /> 1961 V4A-V4AL-13<br /> V4S-V4SL-13<br /> 1962 V4S-V4SL-14<br /> 1962-63 V4A-V4AL-14<br /> V4A-V4AL-15<br /> 1963 V4S-V4SL-15<br /> 1964 V4A-V4AL-16<br /> V4H-V4HL-16<br /> V4S-V4SL-16<br /> 1965 V4A-V4AL-17 <br /> V4H-V4HL-17<br /> V4S-V4SL-17<br /> 1966 V4H-18<br /> 1975 75ESR75-75ESLR75<br /> 1976 75ER76-75ELR76<br /> 1977 75ER77-75ELR77<br /> 1978 75ER78-75ELR78<br /> 1979 75ER79-75ELR79<br /><br />I don't see yours in there...<br /><br />regards<br /><br />Frank
Franki
actually, I just found this on another boat list.. looks like you friend is right..<br /><br />---------------------------------------------<br />I have a new (TO ME) 75hp Evenrude motor. somewhere between <br />68 and 78.(BEST GUESS) model#75393E.<br />With some work I can get it <br />to start, but will not stay running. The compression is 55 on<br />3 cylinders and 53 on the 4th. I know the carbs need work, which is in <br />progress. But I have no idea what the settings are. It is electric shift.<br />Any help would be greatly appreciated. Thank you, Russell N<br /><br />--------------------------------------------<br />Your motor is a 1963 model and your compression guage must be wrong. That motor should have about 125 lbs on each cylinder. I don't think there is any way it would even fire with 55 lbs. It could be the rings are stuck if it has been setting for a long time. I wouldn't waste too much time repairing anything else on the motor until I verified that it had good compression. If those readings are correct the motor may require repairs far beyond it's worth, unless it had head gaskets bad. Good luck!<br />------------------------------------------<br /><br />Russell,<br /><br />Hope that helps you...<br /><br />regards<br /><br />Frank
