I have a Aquabug 120 which is the same as the Tanaka and Sears Gamefisher. All 1.2 hp. 2 stroke outboards. The motor had been setting for a while before I bought it and would not run. I cleaned the fuel lines, petcock/filter and carb. I also replaced and gapped the plug. It fired right up but will not idle without the choke closed. It runs good at high speed but only idles with the choke closed. When I cleaned the carb, I also blew it out with compressed air. The carb does not have any adjustment screws for high and low speeds. Could the carb still be stopped up somehow? the needle valve looks undamaged and the main jet looks good too. I am open for suggestions.
Thanks,
Chris
Thanks,
Chris
