Hey guys, need a little help here. Got my little project motor all back together and it runs great at wot but not so good at idle. Sounds to me like it starts to knock pretty bad then dies. Too far advanced maybe? Point gap is correct but I'm not sure about the timing.There is a M and arrow on the flywheel and an M and arrow on the case.I did what I thought made sense and with an ohm meter set the points to open when both arrows and M's aligned. Is this right? I might add it's a real PITA to adjust the breaker plate. You have to remove the flywheel and everything on top of it to get to the points.So I don't want to do this too many times.Any Tanaka gurus out there? TIA.
