SouthCarolina1
- Joined
- Jun 17, 2013
- 169
Today I was helping my buddy replace his fuel supply line on his center console boat. When he went to cut the fuel line off the barb fitting coming from the fuel pick up tube the top sheared right off. The tank has a fitting that the fuel pickup tube was threaded in. We tried loosening the fitting going into the tank but the top hex sheared off! The fitting in the tank bottom half is still attached but the top had the threads for the fuel pickup tube. I am considering trying tab what is left of the fitting in the tank to 3/8” npt and then installing a 3/8” to 1/4 adapter and then installing a new pick up tube. Or tap whats left, plug it, and replace the fuel sending unit with a built in pickup. Hindsight is 20-20 so don’t blast me for what we should have done. Any other options or different way of installing a new pickup in a plastic tank? Any advice for moving forward is welcomed. Also this area is only accessible through a 12”x12” opening in the floor under the console. To remove the tank we would have to take the top half of the boat apart. Drop links for recommended parts.
