tank size & fuel gauge for 2003 angler
remj4
2003 18' angler 180.
Anyone know the fuel tank size for this boat?
Fuel gauge is stuck on Full. Has power & I did see it down to half tank last outing. Anyone know the type of float in this tank? Was thinking the float is stuck & if I tap the top of the tank by the fuel pump it might unstick & work correctly. Any thoughts?
Thanks
joe09
Re: tank size & fuel gauge for 2003 angler
in the rear or the boet there should be a screw cover that has acess to the fuel tank.disco the wire on top of the fuel sending unit,the guage should read empty.if not the wire is grounded to the gauge.if you need a new sending unit,get a replacement from angler.
