tank vent
Where does a 6 gal. OMC portable tank vent? It has a nonvented cap. Doesn't it have to vent? This is not the type that has the vent knob.
OBJ
Re: tank vent
Rosewood...if you look at the connector, you will see two small pins sticking out. One pin opens a small valve that lets fuel into the fuel line. The other pin is a vent. Both open when the fuel line connector is attached to the tank connector.
Re: tank vent
Thanks outboardjim, one more question, where is the opening, is it under the pin? I'm trying to see if this tank is venting.
