1992 Merc 5.0L V8
I need to replace my ignition module, but I am not sure what I need. I found what I thought to be my serial (based on the manuals description of where the serial plate is) but it doesn't seem to match the typical format 10243878.
As far as I can tell, the part number I need is 15899T01, but when the dealer looked it up, he said it was no longer available. I have found a module online, but he does not have a part number. The picture looks the same, but it may be much different than what I need? Here is the info on the one he posted:
You are bidding on a NEW (Not in BOX)
Mercruiser Ignition Module
Thunderbolt IV
V8
The number on the front reads: 4C17A V8-24
on the back reads: 4C11AA
The connector has 6 prongs
I noticed on my existing that mine says v8-22 does that mena the V8-24 listed above will not work?
Attached are pictures of the one I currrently have installed, and the one for sale.
Has anybody replaced one of these? It looks like it is riveted onto the plate...do you just drill out the rivets?
Thunderbolt IV
V8
