Re: TBX or rubber hub
Fyi, I got this off another site for anyone who would have a similar question
The BRP TBX propeller hub is a field replaceable item. There is a plastic insert which provides the couple (in lieu of the usual rubber coupling). The concept is similar to the popular Mercury FLO-TORQ series. There is a splined metal coupling to the propeller shaft; the plastic coupling lies between the propeller hub and this metal coupling; the torque is transmitted through the plastic coupling.
There have been some anecdotal reports that the TBX propeller hub was developed because the new E-TEC motors were so powerful that propellers with rubber hubs were being spun frequently, and a field-replacement type hub was deemed necessary.
View Member Profile
Hi, Jim answered your question well. If I had the choice I would run the TBX hub for the reasons he mentioned and the Viper with the pressed in hub will be quite old because for the last about 18 months the Vipers have been TBX.
I personally have not seen any TBX fail, but if they did you can just replace the hub and get going again, without having to rebush the prop.
No disadvantage with the TBX, just all advantages.
Cheers,
Huey.
