TC-W3 Oil Testing Procedure
CharlesW
Can someone direct me to a site that would describe the actual test procdures that an oil is subjected to in order to meet the TC-W3 requirements?<br />Something like 20 years ago, I read the original testing that was done at that time to meet the TCW rating. As I remember the article, the motors were put through some almost unbelieveable punishment, high loads, run with less than proper mixtures, run at constant high RPM, basically run till they should have been destroyed. That article sold me on using nothing but TCW rated oil at that time. It would be interesting to me to see what the standards are today.<br /><br />Charles
lakeman1999
Re: TC-W3 Oil Testing Procedure
TC-W3 lubricant, an NMMA owned trademark, has evolved over the years through much testing and research, and has proven to be the level of quality to satisfy the above objectives. And, going a step further, now that two cycle engines have moved towards higher cylinder temperatures and compressions to meet the EPA emissions reductions. <br /><br />TC-W3 has demonstrated the necessary lubrication performance quality needed for these more demanding cylinder/engine conditions. <br /><br />NMMA licenses those two cycle lubricants that meet the stringent performance tests conducted by any one of the three sanctioned laboratories approved by NMMA to conduct the tests. <br /><br />The tests include varied bench tests for fluidity, lubricity, viscosity, etc., plus the oil must meet minimum ring sticking and carbon build up on pistons in engine tests. The engine tests include one OMC 40 hp, one OMC 70 hp, and two consecutive Mercury 15 hp tests. The tests are run for 100 hours each and the engines are stopped every ten hours for inspection. The chemical make up of the TC-W3 oils vary due to the various additive packages involved with each oil brand. Accordingly, it's a performance based qualifications program. The process is very involved and expensive, but worth the outcome for consumers and manufacturers. <br /><br />TC-W3 oils are licensed around the world and are recommended for use by two cycle engine manufacturers. <br />
This is from the NMMA website, it also states that walmart tcw3 is from shell oil company. :D :D :D :D
seahorse5
Last time I checked, you could buy the oil test manuals from NMMA for about $50 each. One was for how the test was conducted and the other for how to interpret the results. There are a series of tests, not just one or two, that each oil has to pass. Different outboards are used and have to be measured and certified first. During testing phases, they have to be torn down and inspected. Having the oil tested by one of the labs cost around $200,000 plus a yearly registration fee.<br /><br />I have read the manual over the years and know most of the procedures. The TC-W3 spec came out in 1993. The original TC-W spec was implemented in arounf 1969.
