TD needs a little help 25 hp Jonny 1993
tashasdaddy
OK so i was brought this motor, partially in pieces, owner let neighbors teenage work on it. i have done many of these motors, buy never really paid attention to where the throttle cable mounts, looks like the end attaches to the throttle linkage on the motor,
but where does the cable holder mount.??
tashasdaddy
Re: TD needs a little help 25 hp Jonny 1993
maybe i need to be clearer. i don't need remote cable, the kid disconnected the throttle cable from the tiller. all is entact, except, i don't not where it actually connects. this is the end of the cable from the tiller handle.
tashasdaddy
the cable is in green, i know it needs to connect to the throttle linkage. yellow.
Cofe
Here ya go.
There is a aluminum spacer that goes under the end where the bolt goes.
tashasdaddy
that helps a lot. thanks. now to find what the kid did with the part.
Cofe
I hate basket cases also.
If the spacer is missing, look around in the cowl. It likes to fall underneath the carb when the bolt is taken out....Good luck
