Teak can be varnished!!!!
santana21
Teak is beatiful varnished!!!!!!!!!!!!<br /><br />I have a sailboat full of it, inside and out.<br /><br />Use whatever means you see fit to clean it. I have found that using the teak cleaner /brighteners that contain oxcalic acid work fine but leave the wood rough and you will have to sand anyway.<br /><br />Sand smooth, at least 150 grit-220 grit paper<br /><br />WIPE WITH LAUQUER THINNER!!!! This gets rid of the surface oil and allows the first coat of varnish to penetrate.<br /><br />Thin a good marine varnish (I use Interlux Goldspar polyurethane exclusively) about 10% whith their thinner (216 becuase I apply with a brush) and coat. Don't even bother with sthe stuff they sell at the local hardware store. The UV packages they add are nowhere near the level that a professional finish like Interlux uses. You will pay more--Around $26.00 per quart, but the proof is in the can.<br /><br />I use a foam brush that I throw away after each coat.<br /><br />on later coats go to about 2-5% thinner. I am never able to use the stuff out of the can and have a flawless finnish without thinning, just doesn't self level.<br /><br />8-10 coats to have that awesome " deep" look sanding lightly in between. I have found that a "fine" grade foam sanding block works best and the grit lasts longer than paper.<br /><br />Let cure for about 7 days after your final coat<br /><br />Wet sand lightly with 1200 grit paper. I can never get varnish to dry without picking up some dust particles from the air.<br /><br />Use a foam buffing wheel and buff with liquid rubbing compound medium grit.<br /><br />Looks like a million bucks!<br /><br />Takes a fair amount of time but the results are worth it. There is not an oiled piece of teak in this world that comes close to looking as good as a good varnish job. <br /><br />The biggest enemy of varnish I have found is UV. Water doesn't seem to hurt it but the sun will just cook it. I had a deck cover made to go over just about everything that is teak. I expect that I will have to recoat--not redo, everything in about three years.<br /><br />My work all came up front and oiling isn't a 1/4 of the work but it has to be vigilantly maintained or the teak will go grey and you have to start over.<br /><br />This is just an alternative opinion from a guy who likes shiny wood.
mellowyellow
Re: Teak can be varnished!!!!
once you do this, u are asking for a TON of<br />maintainence to keep it up. oiling teak is<br />a lot easier than sanding and varnishing<br />every few months...
Captn Dave
I varnish teak also. I have a ship's clock and barometer stands that I made from teak that I varnished. They look great sitting on the mantel.<br />On my boat..............NEVER!!!!!!
LubeDude
I can tell you with experience, "NEVER" Varnish Teak!!! Its too oily allready, Oh, it will look good for awhile, but the varnish will eventually crack, then you have a real mess on your hands. I just had to strip and reoil a whole boat full of it. Dont do it. Especially if it is exposed to the elements.
90skichallenger
Amen. When it comes to teak just take care of it with a good teal oil every now and then and it will be much less labor intensive.
DangerDan
I posted this in another teak topic Check this out!<br />I re-finished my teak on my Slickcraft two seasons ago. I don't have a lot of teak but a considerable amount. All the same it was a lot of work. In looking at all the oils available I considered the amount maintainance that was needed and just for kicks went with a different oil not actually on the long list of teak care products. The name of this stuff was "Watco Oil". You can pick it up at most large building supply shops (home depot and such). It is applied with a rag like most oils. It has a varnish in the oil and every time a coat is applied it seals the wood with a thin coat of varnish when the oil penetrates. As most know teak will flake varnish due to the oils in the wood, however this product has kept my teak in excellant condition not flaking or darkening and keeping the reddish blonde look with much less attention. I have only had to put a coat on in the spring each season and it last thoughout the year. This is the middle of the second season and the finish is still great!!!
CATransplant
Watco oil is terrific for finishing all sorts of hardwoods. I've used it many times, primarily for furniture projects. The more you apply the better the thing looks.
LubeDude
Yes, this is a great product, but it can be over applied. I think that the thing we are all saying is that you should not use a regular varnish.
stevens
The wooden boat tradition is very much alive here in Scandinavia, and you might enjoy these examples. These are links to ads for boats that are currently for sale in Norway. Lots of beatiful varnished mahogany and teak to be seen in the topsides and interiors, with the hulls often being made from pine on oak:<br /><br /> http://www.finn.no/finn/boat/used/result;pdc=1118308650867?sid=9aGJYc_L0595552&page=1&rows=30 <br /><br />If that link doesn't work, here are a few links to some builders, and a directory of many more for those especially interested:<br /><br /> http://www.eikelitrebaat.no/ <br /> http://www.sandoybatbyggeri.no/products.htm <br /> http://www.woodenboat.net/eng/index.html <br /> <br /> http://www.startsiden.no/kategorier...jer/motor_og_transport/bat/batbygging/trebat/
WSUDERMAN
Another vote for Watco here. Been using it for 4 years and our swim platform looks better each year.
CalicoKid
I use Snoseal, the beeswax paste for leather boots and the like. It looks great and keeps the teak good and oily. I also use the stuff on my cars and jeeps leather seats, my concrete countertops, etc.
18rabbit
I use two-part epoxy. OK, I haven't tried it on teak, but if teak ever shows up on my boat it's fair-game for some experimentation.
BillP
You don't have to worry too much about teak showing up on modern boats. Due to high cost, it started being replaced on MANY name brand fiberglass production boats by a lookalike wood from S.America in the mid 1970s. Only a trained eye can tell the difference. It isn't as oily but resists rot well. I think they informally called it "spanish cedar" and was one of the trade "secrets" of the boat building industry.
Boomyal
Originally posted by Stevens:<br /> One final reference to some Scandinavian examples, both 22' open cruisers, one made by Polar Boats, the other by a boat builder called Viksfjord.<br /><br /> http://www.vimenn.com/?article_id=23121
Beautiful craftwork Stevens. Thanks for posting them. Scandanavians must have a lot of time on their hands to keep those boats looking like that.
Paul Moir
Less UV ;) :p <br /><br />18Rabbit, do you put anything over the epoxy?
