teak trim is white in color how to bring it back
reefrunner7
The teak wood and trim on the boat has turned white from not being treated how can it be brought back to a good looking wood color?
cr2k
Re: teak trim is white in color how to bring it back
Mcguires makes a Teak Oil that works good. I get the golden teak oil, but I thin it comes in lighter or darker too.
Tahorover
It's a three step process. First you clean with an alkaline detergent. This will remove all the dirt and old finish. Step two is a acidic wash. This will remove all the oxidized wood. Oxidized teak is sliver or white in color. Step three is teak oil or teak finish.
smokeonthewater
my system may be all sorts of wrong BUT I pressure wash, dry, sand, and then go with a system of cleaner, brightener.... dry, sand again, and finally finish.... either teak oil or other more permanent finish
jdlough
I just blast it with a pressure washer. Done. Protect the wood with the oil of your choice.
superbenk
This is what I do. Worked great for me.
reefrunner7
ok so no varnish or anything required then?
rockyrude
Teak by nature is a very oily wood, no varnish/urethane will stick for very long. As others have said, teak oil is best just touch up as required.
