Tecumseh 7.5hp outboard boat motor
etmcook3
I have a 1973 Ted Williams Tecumseh 7.5hp outboard boat motor.I'm trying to find parts to fix it but i cant find anyone who sells the items.Im needing a std rings ,gaskets and seals.The model #640-13 Serial #7725173.If anyone can help me or tell me where i could get the parts i would greatly appricate it.
CATransplant
Re: Tecumseh 7.5hp outboard boat motor
That outboard was made by Eska for Sears. Parts are available from www.certifiedpartscorp.com, who bought all of Eska's parts when the company folded.
Call the number at the website with your Sears model number in hand, and the guy there will be able to tell you if he has the parts you need.
That said, I wouldn't spend much on your outboard. Its value, even running, is quite low, and you'll likely spend more on parts than the engine is worth. There are plenty of running 7.5 Ted Williams outboards out there for $100 or so.
At best, they're adequate, if noisy, shaky, and hard to keep in service. Any Johnson or Evinrude 6hp will run circles around them. Maybe even a 5hp.
pkrainert
I agree. i had a ted williams 7.5 and i spend a lot of time working on it. i got stuck every single time i went out on it. its so loud and shaky its embarrassing... save your money sell it if you can and get something else. just my 2 cents i bought a 2001 8hp johnson for 400 bucks and its so much faster and you can barley hear it at idle.
etmcook3
Thanks so much for helping me!!I agree my aluminum boat is paid for too.
don_b
SORRY CAN'T FIND THE RIGHT PLACE TO SEND MESSAGE DIN'T MEAN TO DO WRONG. are the Tecumseh and Eski the same motor I need the uppper crank case that carries the coil, and upper crankcase bearing, mine was broke when I got,it,it a 71 t- 640-09 thanks for your assistance
dude11
Where are you located?Reason--I have a 7.5,(like yours) 1976,new impeller,rebuilt carb.cleaned fuel tank,new fuel lines & filter,all new gaskets.Runs great,I just couldn't warm up to no reverse.lol.I do alot of limb & trott lining,so rev.is needed.But it's for sale--I'm in Ga.
don_b
Hi dude11, i guess your talking to me i'm in Kansas. my motor is 1971,7 1/2, Techumesh, need upper crankcase bearing cover that holds the electranics, broken and I think it sucking air, have ran a compression check, just looking at the brake, any ideas. Thanks
dude11
It was to anyone reading etmcook3's post.On your question--You may want to start a thread yourself on that problem--highjacking (lol) is a no,no.--Back to hand;Can it be welded? Tig is a wonderful thing.Good luck and fair winds to ya!
