Tecumseh Sno King, carb questions
I'm getting ready to install a new carb on an old Tecumseh Sno King motor, Mod# HS506711830 Ser# 9257B.<br /><br /> The carb I got, part # 640084B is slightly different, I believe it will mount up perfectly but the is no mixture adjustment screw now and the device on the bottom of the fuel bowl looks like some sort of drain or relief.... push button of some sort? (When I say there is no mixture screw, I should note that in the general area of where the mix screw should be, there is a plastic cap. <br />The old carb had a mixture screw on the side and an adjustment of some sort on the bottom of the fuel bowl.<br /><br />Question/s are: <br />1) can someone tell me if this is the correct carb? Maybe just a current version? (The snow blower this motor is on is about 30 years old).<br />2) is there a mix screw under the plastic cap? It is recessed, and would be difficult to try to grasp it.<br /><br />Thanks in advance-
