Hello. I am new to outboard motors and their repair but was given a Ted Williams 7.5 HP motor to use on my 14' aluminum boat. I believe it is a 1973 year. I apologize if my questions below make no sense but would really love to have this motor running.
I has been sitting for around 20 years. I cleaned it up, changed the spark plug and started the engine. It runs great and speeds up and slows down fine when I twist the throttle.
When I flip the switch on the side of the motor from Neutral to Drive however, the prop does not begin to turn. I opened up the top of the motor and it appears all the switch does it limit how much the throttle can move?
Also, there are 2 holes at the top of the prop shaft that have exhaust venting from them...is water not supposed to be coming out of them? Water pump trouble?
Any help would be greatly appreciated.
