Ted Williams, Water leak under the engine
emtoly
So, now that there's life in the beast, running strong, thanks to much help from the forums... There is water leaking right where the white engine parts meet the green outboard leg. There is water spurting from the outboard exhaust port as per normal as well.. Is this a big deal? and if it is anyone have a better schematic than this : http://www.searspartsdirect.com/par...on=COLUMN ASSEMBLY&documentId=00035597&blt=06 Must be an exhaust or water gasket of some kind that's bad? Thanks again :);)
M
mrcrabs
Guest
Re: Ted Williams, Water leak under the engine
call www.certifiedpartscorp.com, the have a web site but you need to call them, they bought what remained of Eska, who made your Teddy, you can get your part numbers from the sears diagram and then call certified, they have what you need and generally will have the best price, including your new fuel pump, which will cost you 10-12 bucks alone, gaskets are cheap enough
